hey guys
i have a 1953 ford f100 with a SBC 350( dont know the age ) , i was have oil pressure issues, so i pulled the oil pan and installed a milling HV oil pump new shaft and new pickup , i followed the instructions by milling ,, i would of liked to pull a cap while the pan was off but didnt , anyway now on cold start i get about 45 to 50 PSI . after hot driving i get maybe 25 at 1500 to 2000 RPM ,, now at idle i get lower , its hard to tell by the new gauge i am down around the first and second line below the 25 and thats around 700 rpm ,, my question is should i pull a cap and check the bearings , and maybe change them ??? the pan is easy to pull , or through a can of additive, i am running 40w oil and a wix filter
thanks
thanks
