what is a safe time to run motor without oil pressure ? the motor has assembly lube in it at first ,we are doing a motor swap and didnt get oil pressure due to a plug missing in top of oil pan , anyway we fixed that and now we have have oil pressure at high RPM then drops on at idle , could we have cooked the cam bearing or something else , its a new motor rebuild 6.0 LS we did pack the oil pump ,,
thanks
thanks
