Oil Pressure Gauge
ON, Canada eh?
So my el-cheapo oil pressure gauge I got for $20ish from Princess Auto stopped working.
I kinda new I should of bought a better quality one but I couldn't resist the price and thought I might just get away with it.
Well I was wrong... Now my questions is this...
Because I wired in this one which has an electronic sending unit what would be a good replacement for it that I could just splice into the existing wires I ran.
I'm not looking to spend crazy $$$ like on a Sunpro but I want something that is accurate and that will last longer than a year.
Mehh it's up to you bud but if you want it to last...
in the states here you can get just the oil for under $20 probably twice that their.
With the electronic sender or is it a mechanical gauge with tubing?
I would like an electric one because it would be easy to replace this one with.
I have been using this one for 4 years and 60k miles. I had a sender start leaking where the wire hooks up, but Autometer sent me a new sender free of charge and shipping even though the sendor was 3 years old at the time.
Either one..price around on line maybe you can find cheap on line that ships up to you guy's
I will just get something off the shelf from AAP or AZ next time I'm state-side.
I just wanted opinions in case there was a really good gauge on the cheap.
I didn't want anything but a stock look for my dash, so that is part of the reason for the switch I put in the oil pressure line. If pressure falls too low, the electric fuel pump shuts down. without fuel, I will never run with low oil pressure.
Why did it quit? Is it a bad gauge or a bad sender? Just change the bad part, probably a fluke failure.
It's a bad sender unit because of what's happening and the gauge doesn't have spec's so I can match it with a similar sender from another manufacturer.
