Truck is an 03 Dodge Ram Cummins. Bypass is a Gulfcoast O-1.
I have a mechanical oil pressure gauge on a "T" at the port I'm drawing oil pressure from (oil filter housing).
I get quite a drop at cold idle (from 65 psi to ~50 psi) with the bypass running wide open. I have an inline needle valve on the input side and I can choke down the flow so the pressure returns to almost normal. With the flow choked down this way the filter still gets good and hot at operating temp so I know I'm getting flow through the filter. I have not attempted to measure the flow rate yet.
How big a concern is this pressure drop? Is the needle valve an acceptable solution? How far can I choke down the bypass flow and still get good filtration?
Thanks,
-john
Thanks,
-john
