Originally Posted By: 440Magnum
Originally Posted By: widman
It is not a myth.
It is fact IF you have rebuilt the engine. The factories have much better torquing of parts, absolutely clean and perfect surfaces, etc.
When you rebuild it, your torque wrench probably isn't perfect, you are probably reusing bolts, your machine shop probably isn't as well qualified and equipped as the factory.
I disagree with almost everything you say here, unless you're using the cheapest machine shop in town and are doing a true 'shade tree' rebuild.
People doing rebuilds these days fall in two camps: trying to eke a few more miles out for the fewest possible dollars (the shade-tree rebuild), or those who are either restoring a vintage engine for a collectible car or are building a racing engine.
The latter camp uses good machine shops that take more time and execute to FAR higher precision than any mass-production assembly line can. The assembly lines have gotten far, far better since the 60s, but they're still mass production, automated, parts are grouped by crude "binning" to similar dimension/weight rather than hand-fitting with careful measurement, individual component balancing, etc.
All that said, whether to break in with synthetic or conventional oil really doesn't matter, IMO. No oil is "too slick" to let parts break in if the proper break-in procedures are followed. The additive package for break-in is more important than the base oil (especially for certain kinds of engine, like non-roller cam engines), and there are lots of very good break-in oils out there. Since break-in oil is not there for extended use, extremely cold starts, extremely hot operation for extended times, etc., it simply doesn't NEED to be synthetic, so most break-in oils are not.
widman is from Bolivia. In his part of the world, a lot of what he says is true.
