Got a 1996 Yamaha golf cart. I use it around the yard.Works great, runs great. Changed the oil today. Put in 5w-50 Castrol Syntec. Now theres a oil light that will come on if oil gets too low, not a oil pressure light, this is a oil level light. Keeps golfers from running the carts out of oil. Anyway this light always comes on when I drain the oil, and has always gone out after I start it with a new fill. Reason I know this is I seldom turn off ignition key, because when you let off throttle it kills the ignition. Only reason to turn off and remove key is to lock ignition.
Problem today is the light wont go out after runnung the cart. All over the yard and down the road a mile , light still on. Motor holds 1 qt. oil is right at the full on dipstick.
What kind of a light system is on this anyway? Any ideas as to why this light wants to stay on now.
