I have a Briggs & Stratton 7.75H.P. engine on my Craftsman snow thrower that is leaking oil. Engine model number is 12C314-0131-E1. Engine is 15 years old but still runs like a top. Oil is pooling at the front lower corner where engine is mounted to frame. I cleaned the engine up thoroughly to try to pinpoint. I originally thought that the front PTO side oil seal was the culprit but that is not so. The definite area is the area that I originally mentioned. Could it be the rear oil seal (flywheel side) which I cannot see? I am pretty handy as I changed both belts and idler wheel yesterday and as you all know that is not the most easy job...splitting the snow thrower to change the belts and taking the drive apart to change the idler wheel. Hope I did not waste my money. That would have been the time to pull the engine to take a closer look but did not want to go through all that trouble before asking you all. Maybe it is time for a new snow thrower??? Thank you all for any help that you can provide.
