Alright. So I've got a question.
So ford says 5w-20 is fine in a dohc 4.6. Apparently 10 pounds per 1000 rpms is the accepted oil pressure in a performance application. What if I put in a higher volume pump,could I in theory use thinner oil and still attain the desired 10 psi per 1000 rpms. Engine does have an oil cooler.
What is I used thicker oil? What possible outcomes could be expected.
Again. Hypothetical. Comments......
