oil for winter and chrysler spec
Michigan
hey guys im really needing and oil change soon and since winter is around the corner what oil is best for cold conditions? would i be ok with a conventional 10w30 in my dakota? and also does supertech and , Mobil 5000 meet the chrysler oil spec? thanks
Chicago Area
As you noted, car oil has 2 numbers [like 5-30]. The first is for cold flow/thickness, and the second for hot flow/ thickness. There is a saying around here: "No oil is too thin at start up." Always use the lowest first number . In other words, a 5-30 is better than a 10-30. A 0-30 is wonderful, but is going to be a full synthetic and more expensive. A 5 first number is great for most of the USA. I consider a 10-30 to be obsolete at this point.
b16jose
Michigan
so 5w30 would be better even tho the manufacturer recomends 10w30? also i shouldn't have a problem running synthetics in a higher mileage truck correct?
indiana
I use 5w30 in my dakota, year round and it works well. Even through 100 degree heat hauling cargo. 10w30 like another person said is obsolete.
