I've been running Stihl 4-mix since 2005, along with 2 stroke Stihl and Echo. Never have had a failure, and never adjusted valves until recently when a rubber grommet got caught in the flywheel of my fs100rx making it hard to crank so I checked the valves. They were very close to spec but I adjusted them. When the machine still felt very tight when cranking I discovered the loose grommet. So... the cam gear looked great and all has been remarkably reliable with ten years of commercial use and ten additional years of residential use. I've used various oils and have several brands in my garage. Super impressed with how clean VP is. But unsure of it's lubrication. Red Armor is now being used... Oh, and I see that Echo's new pb5810t blower is a 4 stroke mixed fuel design....
So I'm asking you guys what oil at what ratio are you using in your Stihl 4-mix or Echo pb5810t, and what is your impression? Looks like the 4 stroke design is starting to spread, like it or not.
