I just bought a Pressure Wave Pwr Washer w/ 5.5 HP Honda engine from Sam's Club. Has 2500PSI and 2.2GPM.
The unit came w/ a bottle of Honda 10/30 API SJ oil. Label says its for generators, power washers and other 4cycle engines.
Should I use the OEM oil?
I have a stash of the following that I could also use, all synthetics and API SL.
Quaker State 10/30 Syn
Valvoline Maxlife Syn 10/30
Mobil 1 SuperSyn 10w30
What do yall advise?
Unit will be used in South Texas heat.
How often should I change oil if I use OEM and how often if I go the synthetic route?
Thanks in advance.
Thanks in advance.
