I've been contemplating going to a 5w40 and I'm a bit partial to Mobil 1 products. My Walmart recently started carrying the Mobil 1 Turbo Diesel Truck 5w40 and I'm thinking of making the switch, but I've yet to even find a VOA for it. I'm curious of the ZDDP in the oil as I run a ZDDP additive in mine and I'm getting sick of making motor oil cocktails if the 5w40 is as good of a solution. Right now my mix is 4.5qts Mobil 1 5w30, 2qts Mobil 1 15w50 with 1oz of ZDDP Maxx. I'm planning on running a used oil analysis after this run to see how it is working out for me, but I've seen used oil analysis for Mobil 1 Turbo Diesel Truck showing 1300 Zinc 1200 Phos which is awesome for used numbers. I already like the viscosity of the 5w40 based on published numbers, but wanted to verify the numbers on ZDDP in particular. I'd also be running it in my V8 S-type as it makes stocking oil easy.
I know that I run a bit higher than necessary ZDDP, but it runs smooth and it's cheap insurance.
