I have been doing alot of searching but still not really sure what to use. The car is a 2006 mistu evolution with a Gt35r turbo kit, built 2.0 and all other supporting mods. The car makes just under 500whp on pump 93 octane gas and just over 600whp on c16. The car rev's to 9k when being raced. The motor sees high boost pressures also, about 25psi on pump and 35 on c16. The car has about 12k on it and about 4k on the built motor. The car came brand new from the dealer with mobile one, i have also used royal purple and amsoil. I usually run 5w-40 oil in the car. Now all you oil guru's out there what do you suggest i use? i change the oil in the car every 1k and use k&n oil filters. What brand oils do you suggest i use? Should i stay with syn oil or go with a dino oil? please let me know what you guys think, thanks.
