Originally Posted By: Shannow
Originally Posted By: 4WD
Several of the freezer tests on the web.
Some folks like to discredit those - regardless - the Mobil 1 does well on these simple tests.
Don't see how an oil pump could pick up 3/4 of them in some of these videos.
It's not supposed to 0W30s are made for the temperatures that those freezer tests are carried out at.
Honestly, and again, I have no idea why people consider a 5W test at -40C relevent when there are grades actually designed for that temperature.
Would mixing them with an egg and vinegar and seeing which made a better mayo give you information about how they performed in an engine (TBN and dispersency) ?
Well, for the moment I feel constrained to 5W30s due to Subaru's recommendation for my engine and the fact that I am still under warranty. Since I have to deal with some very cold temps (weekend skier who parks outside overnight in the White Mountains), I like to find 5W30s with good cold performance. Even for when I am "free" in less than 10k miles, I am still concerned by what seem to be generally higher NOACK results for, say, 0W30 compared to 5W30 oils of the same brand.
I'd really like for some of the warm weather guys here to see what a really cold start is like before blithely dismissing cold viscosity. I ski less than 25 miles from Mt. Washington...granted, I do not see conditions as bad as that bizarre microclimate, but -30F overnight is not that unusual. And, yes, I might start my car early in the morning after a night like that, as I am almost guaranteed to have little company on the slopes (although I might have to warm up after each and every run). That painfully slow crank...the car shaking and shuddering...how reluctant it seems to actually move, even after a warmup. I used dino in my old RAV4 (V6, 5W30) and then tried a synth or semisynth change just for the heck of it...even further South, I sometimes thought my car had failed to start in the cold because it was actually somewhat smooth once it caught. Took me a while to make a connection to the different oil type...similarly, going to M1 and QSUD 5W30 when I started changing my own oil in the FXT made the ski weekend starts noticeably less painful compared to whatever synth the dealer was using. Didn't even know that M1 had good cold viscosity for a 5W30 until I had been using it for a while...
Of course, I'm still going to hear some guy in Miami or the Southern tip of Texas tell that me 15W40 is fine for anybody outside of the Arctic Circle and maybe I just need a new battery. Sure, a new battery might help with the cranking...the issue is you rarely know that your battery is getting weak until you actually get it in the cold. Why not just use an oil that will strain it less in the chill and still protect your engine very well in other conditions?
Believe me, I understand that my application is not typical and I would probably be fine with 10W30 if I did not ski, given that my car is garaged overnight in a less harsh winter climate at home. Just saying that dealing with really cold conditions is way different than reading about them.
