Valvoline VR1 10w30 would be my choice.
Thank,s that's good to know. I only use it in my two generators and a pressure washer. I'm sure they are OK with this new formula. I guess it would be OK for a stock 72 Small Block Corvette, if not there are lots of other oils to use.Mobil 1 High Mileage 10W-40 has been updated by Mobil recently and has 900ppm zinc & 800ppm phosphorus. It no longer has "a bit more" as it did a few years ago.
Mobil 1 0W-40 has 1100ppm zinc & 1000 phosphorus.
https://www.mobil.com/lubricants/-/...iles/FAQs/mobil-1-oil-product-specs-guide.pdf
Enjoy the Vette! Here's mine:
Actually gm went with low compression and peanut plugs in 71. This is also the era when GM could not keep cam lobes. It was almost always the low performance 929 cams in the L 48 that rounded. The performance cams seemed ok.I would try and learn more about the engine. Is it the original? Is it rebuilt?
1972 was the 1st year for reduced compression ratios.
If the engine uses a flat tappet camshaft, valve spring pressue may dictate the use of an elevated zinc oil.
Here is the new Castrol oil I really like: Castrol Classic Oil
Walmart has it.
If the oil change has been neglected, I might consider a short OCI with Shell Rotella T for its cleaning properties.
Correct!Actually gm went with low compression and peanut plugs in 71. This is also the era when GM could not keep cam lobes. It was almost always the low performance 929 cams in the L 48 that rounded. The performance cams seemed ok.
You're correct. '70 was the last year of the high compression engines. My mistake. I had a '70 Coupe with a '70 CRR 454. That's the LS6 out of a Chevelle. 4 to 6 mpg.Actually gm went with low compression and peanut plugs in 71. This is also the era when GM could not keep cam lobes. It was almost always the low performance 929 cams in the L 48 that rounded. The performance cams seemed ok.
That's the first I've heard about it. Nice to have another oil designed for flat tappet cams, instead of playing chemist with additives.Here is the new Castrol oil I really like: Castrol Classic Oil
I used to scour picapart for 69-70 impalas with the 300 hp 350. Those had the closed chamber heads with accessory bolt holes and were the cats meow 30 years ago.You're correct. '70 was the last year of the high compression engines. My mistake. I had a '70 Coupe with a '70 CRR 454. That's the LS6 out of a Chevelle. 4 to 6 mpg.
Those heads would have made a huge performance difference on the 307 that was in my 69 pickup. I always like the 300hp/350 as well as the 300hp/327. Net horsepower rating would probably have been 250hp or less, but I suspect they would be plenty powerful even today.I used to scour picapart for 69-70 impalas with the 300 hp 350. Those had the closed chamber heads with accessory bolt holes and were the cats meow 30 years ago.
Made a huge performance improvement over the 75 cc 882 and 624 heads that were so common.
Exactly this. It will have the higher Zinc in it that benefits older cars. I use it in all my classics.Valvoline vR1 and the longer ph5 filter
True! Mobil 1 High Mileage used to be the best kept secret for high zinc oils until they revised it, I think around 2010.Mobil 1 High Mileage 10W-40 has been updated by Mobil recently and has 900ppm zinc & 800ppm phosphorus. It no longer has "a bit more" as it did a few years ago.
Walmart has it.
It was neat looking through the manual several posts up. I figured a 350 from '72 would have a much bigger sump. And I didn't realize 5W-20 existed back then.Here's a good cite reference that gives the years of Corvettes and mechanical information, including oil weights and capacities.
https://corvettestory.com/specs/1972-Corvette-specs-options.php
For 1972 it states, for the 350 engine:
4.5 qts of oil with filter change.
Oil recommended:
Above 20°F: SAE 20W, SAE 10w30, 10W-40, 20W-40
0°F to 60°F: SAE 10W 5w30, 10W-40
Below 20°F: SAE 5W, 5W-20, 5w30
The SAE grading system was different back then and you cannot compare today's 5W-20 oils to what was sold then. It was pre-HT/HS but back then 5W-20 would have likely had a value around 2.9 or 3.0. This is why the first Mobil 1 oil (5W-20) was marketed as a replacement for 10W-40.It was neat looking through the manual several posts up. I figured a 350 from '72 would have a much bigger sump. And I didn't realize 5W-20 existed back then.
Always and forever Mobil 1 for CorvettesI get the privilege of changing oils in a few of the family’s sports cars over the holidays. One of them is 72 corvette stingray with the 350 in it. Oil change history is… not good. It runs well but it’s been several years since it’s been changed, and unknown what oil. I was going to go with Valvoline MaxLife Synthetic 10w30 but is there any reason not to? Not sure if they’re syn blend would be a better fit. I doubt synthetic has ever been run through this. I was also going to pair it with an acdelco pf454 filter to keep it simple.
Brand is the last criteria here.Always and forever Mobil 1 for Corvettes
But its the most important criteria here oh yes it very well is .Brand is the last criteria here.
