The Mitsubishi 4G15t Mivec Engine is in a colt ralliart I just purchased.
http://www.ralliart.com.au/RalliartVehicles/ColtTurbo.aspx?item=1
I can't find any info about the factory fill of this vehicle, after taking delivery from the dealer when i got it home, it did need to be topped up with around 1/2 a quart so i used
http://www.tds.castrol.com.au/pdf/4399_EDGESport5W30_119240_200603.pdf
I have plenty of this 5w30 edge on hand, and plan on getting the factory fill out at around 1000km, what do you guys think?
I also have a lot of Mobil 1 ESP 5w30 on hand
http://www.mobil.com/Australia-English/Lubes/PDS/glxxenpvlmomobil_1_esp_formula_5w30.pdf
and wanted to use this also, what do you guys think re using a 5w30 in this engine?
The Service book has a bias towards a 40 weight multigrade, however i feel more comfortable running a slightly thinner oil.
