The vehicle is a 1996 X90 (Geo Tracker with a different body). Engine is the 1.6 version.
Photos from the owner's manual are below. It states in no uncertain terms that 10w-30 is preferred. However, the chart would seem to indicate that it's not useful above 86 degrees. If true, that doesn't seem like a very hot temperature for a default oil recommendation? Thoughts?
Also, would this engine need ZDDP above what's currently in normal oil?
Thanks.
Thanks.
