How much difference in viscosity and flow rate is there between a 0w-40 and a 15w40 Syn oil @ an ambient outside temp of 50-70 deg F. This temp range is well above where both oils need to be for cold weather starts. Wouldn't they be virtually the same at that start up temp? The range for each oils usage over laps and should be the same in the overlap temp area? Or am I missing something that someone can explain to me?
So @ 0 deg one acts like a 5w and the other a 15w, and at 100 deg they both act like 40w. so at 50 deg they should both act like 20w-ish?
