Originally Posted By: ctc
Originally Posted By: takax2040
The filter says made in Indonesia.
The filter is mounted at the bottom of the engine with the inlet/outlet holes facing up. Does that qualify as point down.
My concern is the high ambient temps and hot oil temps wearing down the ADBV. Kinda like how rubber wipers don't last for long in Malaysia weather. Not sure if it's the UV or heat.
Yes that is what I meant and as bepperb stated, this means you don't need an ADBV at all so it doesn't matter what material it is made of...
Absolutely untrue, I have no idea how this old wives tale hangs on for year after year! What you need the ADBV for above all is to keep oil from draining out of the passages in the upper block that usually lube the cam and lifters. The orientation of the filter has no bearing on whether or not oil will drain down from these upper passages thus causing them to have to be refilled before the cam and lifters are lubed.
If the oil filter is full, how can more oil drain into it?
Besides the ADBV keeps oil in the filter from draining out so how does that accomplish what you're describing?
Go read this thread
http://www.bobistheoilguy.com/forums/ubb...;gonew=1#UNREAD
