Originally Posted By: Bruce T
Thanks, I think I understand. You're saying the ISO efficiency rating is measured when the filter is at its maximum capacity. That's not very helpful in the real world, since its filtering efficiency at the unloaded level is unknown. I strongly agree that the nominal rating is the most useful number given.
I also think the EaO/RP, if tested, would have been categorized with M1/K&N.
Yeah, that's the basic idea. It's not something cast in stone, it's just some "latest revelation" in my ongoing expansion of perception on this whole filtering thing. It's surely subject to critique and alteration.
For example, when we're shown flow
SID curves, how would they appear near the multipass rated level of filtration? Not nearly as good as they do clean where they're well below their published "best" filtering numbers. The two figures are somewhat divorced, IMO ..or so I reason.
You now have a new axis of influence on how you rate a filter. While a figure of comparative performance may be useful, which one alters your view?
2/20/75 = 5/10/20 vs. 10/15/30
10 PSID @ 10gpm vs. 10gpm
10gms holding capacity vs. 8gms?
In this case it will take longer for the higher efficiency filter to reach it's rated level and the (alleged) poorer filtering filter may give better filtering performance (massage the numbers to make the concept work).
If you never reached either 8 or 10gms, how would you know which one is really working better?
That's why I see the nominal rating having more merit than I have given it credit for ..and how a 25k rated EaO can show poorly in comparison to a 15k rated M1 in a 10k particle count comparison; and even more poorly in a 5k comparison.
