OVERKILL
$100 Site Donor 2021
Originally Posted by burla
Yeah, tell that to the guy who bought two 6.4's and had them both have cam fails.
Tell him what, that he doesn't have an SRT 6.4L? I'm pretty sure he's aware. Or are you speaking about your God complex?
The largest point in this silly conversation is there is no downside to using hearty oils. At least at that point you have done what you could. mic drop, carry on
I never said there was. I simply pointed out that the issue doesn't seem to exist on the SRT 6.4L on two different 0w-40's with different levels of moly. It's an observation about the moly content, as both lubricants likely have it sourced from Infineum. The SRT engine also has a different camshaft, as I'm sure you are aware, and likely heavier valve springs, both of which are points I believe we've discussed previously.
