Oil filter stuck??
New York
Oil was changed at Midas and a gorilla put on the filter. Now, my cap wrench slips on the filter and I can't remove it. I usually do my own changes and use pur classic filters, but now after King Cong tightened filter, I can't get it off.
Help.
Screw driver and a hammer. Pound it through the filter and turn the best you can. Repeat as needed.
Try stuffing the filter cap wrench with paper towels / rubber band first
Channelock oil filter pliers will remove almost anything
I like the pliers best. Even the thin ones for tight spots can get a lot of torque on a stuck filter. That was the only thing that worked on my Acadia after King Kong put on the original filter at the factory.
Donald and tom slick mentioned the two items I would use. I've gotten every stuck filter I've encountered off with one of the two. Sometimes the pliers mangle a filter if you're not careful, though. It's very easy to crush them when you're exerting a lot of pressure.
If a cap wrench didn't work then a screwdriver or pliers or a metal strap wrench probably won't either. A rubber strap wrench or a claw type filter wrench might still work. Sometimes a different temperature (very hot or very cold) can help quite a bit and allow a previously stuck filter to be unsscrewed easily.
Use with caution - punctured through a Motorcraft filter with those and created an even bigger mess.
I would also recommend sticking with the cap wrench, and getting a long pipe which can slip over your wrench. Leverage will help create more force on the filter.
Sometimes you need to walk away for a little bit BUT NEVER GIVE UP!!
Really though I have found when I go back and give it an extra few tries i will finally get that sucker off.
The OP describes a situation that sounds like the flutes were rounded off after trying to remove the filter. At that point, something that digs into the filter can (and basically damages it on removal) is the only practical option. The Lisle cam style wrench should work well, although that one says it's for filters over 3-1/8". Lisle has another one (63600) for smaller import car filters. I've got something similar myself that I bought at AutoZone for $6. It works great but I find that I'll need to open the spring-loaded jaws by hand before slipping them over the filter.
http://www.autozone.com/autozone/accesso...entifier=297190
Some people like 3-legged wrenches though. Similar principle.
Originally Posted By: Clevy
I've got the rubber ended lock jaw type and it's never let me down.
Tried that one when removing the filter on my parents' Nissan Rogue. I had plenty of access, but all I ended up doing was slightly scratching it because the can is maybe 2-5/8" in diameter. The universal claw wrenches have issues locking on to really tiny cans unless they're specifically designed for smaller filters.
I also have a hard time slipping that in when the filter is surrounded by stuff like the exhaust headers on my WRX. For my first oil change I bought a small-sized Lisle band wrench (can't find it now), but my filter was actually too small and there wasn't much room. I sort of got it off after many tries and a lot of slippage.
My first choice is a cap-style wrench if I can't get it off by hand, but failing that I've got a claw and a cam wrench.
For certain applications, a locking cam-style wrench will work better than any other type. It'll work if the flutes are damaged and there are few applications where there isn't adequate space. I've tried the claw in some tight areas, and there's no room to maneuver it.
Mine isn't the same as the one pictured above. And mine will fit on any size filter. It adjusts 3 different settings.
I've had the cap types,as soon as it slips once its bent and won't work anymore.
Before buying my plyer type I was the hammer and screwdriver method. Messy but effective.
Try and grab it as HIGH up on the filter as you can with any of the wrenches the guys are suggesting. The filter is more rigid near the top... I had to do this on a Motorcraft filter that was stuck on my f350 a few months back.
