This is the ultimate that has saved many a real mechanic. The trick is to work tangentally. Get the chisel started near the edge, and then slant it so the force of the blow wants to turn the filter off. If the shell has yielded to the screwdriver, you could catch the edge of one of the inlet holes with a punch. this same technique works on broken bolts, bleeder screws, and rounded nuts and plugs.quote:
Originally posted by Baveux:
if you have room, chisel and hammer used carefully will do the trick
The variation in shell thickness could account for some of the variation of success with the screwdriver.
Since I started using my 16'' Channellocks 10 year or so ago, all my filters have easily yielded to it. I do use a 5/4'' socket on the caniuster cap of my Ecotec.
