I've read lots of peoples comments here about how they found a bigger filter and many other comments on filter size. Looking through my filter book I compiled this little list of all the 3/4-16 thread filters that one could choose, maybe thinking he was doing something good. Although one of those is the synthetic version with much finer filtration, the rest are "standard" media, which may or may not have different micron ratings. Other than the slightly off-size gasket that might blow sooner, note the different relief valve pressures.
My Corvair has a built in 10 psi relief valve, so as long as I have a filter with a higher pressure, I'm covered. But if I chose a 7-10 psi filter it would bypass too soon and not filter.
What about the engines that need the 10 psi filter relief valve if you put the 36 psi filter in? That engine could run dry waiting for oil if it got clogged or oil was too thick for the temperature.
