Originally Posted By: cool_breeze
BTW whats delta p ?
Delta-p means difference (delta) in pressure. Also sometimes called 'PSID', meaning PSI Delta.
Its the change in pressure between the inlet and outlet of the filter due to the resistance to flow of the oil being force through the oil filter by the oil pump.
Here's a graph of what a typical good flowing oil filter will produce in delta-p vs flow with hot 5w30 oil.
BTW whats delta p ?
