Oil Filter Internal Views
Just cut open a Fram TG and an Amsoil filter... how can I post the pictures here? Can't I just download them from my computer somehow?
I put a couple of pictures like that up on my yahoo pictures folder and put a link to it here. Just had to change permission on the folder so that it was public.
Dan
What's up with that Toyota filter? Is that a bypass filter? I would NEVER put that on any vehicle! Unless I lived where the temp NEVER goes below 200 degres!!!!!
quote:
The filter is made from 2mm-3mm thick fiberglass mat, impregnated with some resin material, molded over a plastic skeleton. It's a full flow filter, not bypass.
Ken
[ August 24, 2003, 03:10 PM: Message edited by: Ken2 ]
quote:
Originally posted by RealWing:
This is my Amsoil SDF20 filter!!! Amsoil advertizes 94% Efficiency based on SAE HS806 test.7 inlet holes at 0.250" diameter. Can thickness 0.014"
Black nitrile anti drainback valve. 43 pleats. Pleat depth is 0.525" Cartridge height is 2.1"
Internal view. Bypass valve at top. Many flow holes in the inner support.
This is the bypass relief valve. It has a metal-to-metal seal. It does leak a small amount.
I just want to let everyone know that amsoil is no longer using black nitrile ADBVs in their filters anymore, they are only using silicone now. Also, now the efficiency is rated at 96 and I wouldn't be surprised if the overall construction of the filter has changed too.
