My life was so much simpler before I came here. I was happy-go-lucky, using whatever oil and/or filter I came across. Life was good.
Then I came here.
Anyway, I have a couple different pieces of John-Deere Yanmar diesel powered equipment. Two of them use the same filter (WIX 51365/NAPA 1365) - both are 24 HP, and the other (33 HP) uses a 51064/1064. So, digging around at the WIX filter site, I discover that the 51365 is 20x1.5mm; 2.577" high; 2.685" OD; 2.475/2.173/0.223 gasket; 8-11 PSI bypass; 300 PSI burst; 9-11 GPM flow; 19 micron rating.
The 51064 is the same thread; a bit higher/fatter; same gasket; 16 bypass; 355 burst; everything else the same.
Obviously, it would make my stocking situation much simpler if I just used one filter for everything, assuming either one would physically fit under the hood.
Question - does 5 PSI bypass and 55 PSI burst make enough difference to worry about? I'd prefer to use the 51365, because there's a wider variety of filters out there that show up on the interchange charts. I could even use the Pure One - PL14612 or Mobil 1 M1-108 if I'm feeling flush.
Then I came here.
