Hi everyone,
I did an oil change as always, but unfortunately this time I made a mistake and probably damaged the oil filter stud threads. The new filter wouldn’t thread on smoothly and became difficult at some point. I couldn’t get it to screw on fully. I tried to put the old filter back, but that was difficult as well.
Actually, I didn’t see any visible damage but I did find some metal shavings when cleaning the stud after failed installation.
I’m thinking about two options:
1. Getting a new oil filter housing.
I found the part number: PE01-14-311.
2. Trying to fix the threads with a thread file.
Can you tell me what the process of replacing the housing is?
Do I need to drain the coolant to remove this part?
I know I’ll need a new gasket if I go with the first option (PE01-14-342)
Car is 2016 Mazda 3 with 2.0L engine.
Thanks.
Thanks.
