I'm in the process of retrofitting a 1984 Chevrolet 305 and 700R4 in my 1996 Chevy S10.
I'm looking to add more oil capacity without making the oil pan larger. I don't want to make it any wider nor make it hang below the frame. I plan on lowering the truck so I don't need to be tearing a hole in my oil pan.
I'm looking at going at using a dual remote mount oil filter setup.
Most of these setups using the PH8A ford oil filter.
I have a few questions about the differences between the filters..
This is the OEM replacement filter for the Camaro engine.
The is no bypass valve on it.
Here is the PH8A style filter used on the remote mount oil filter setups..
It has a bypass valve on it, will this harm the engine at all?
Here is the oversize I found for the PH8A...
It too has a bypass valve.
Is it bad to use a filter with a bypass valve on an engine that has a filter without one?
I'm planning on using either two Wix filters or two K&N.
Does the remote oil filter setup have to be mounted at the same height or below where the stock filter would sit, or could it be mounted upon the fender?
