That filter has a much bigger gasket. Cross referencing to Wix for gasket dimensions, it's ID is about the same as the 24458's gasket OD. Are you aware it's been shortened to 3.75 inches per Arvinmentor produce bulletin? It also shows as "discontinued, available until supply is consumed."quote:
Originally posted by Michael Polutta:
Another possible option is the Purolator L20253. This is the filter for the ZR-1 Corvette. It's even larger than the PL24458. The only question is whether or not the gasket will seal. I'm going to test this on my next oil change for our Honda Odyssey. It fits my '89 Mazda MX-6 GT.
I really like oversized filters. Increased flow is good!
Life would be simpler if everyone used the same thread and gasket seat dimensions. It almost started off that way. Ford and Chrysler corp used the same filters at the start in 1957. Some Europeone and Japanese companies used the common 3/4-16 thread. Even Renault in the early 1960s.
Our favorite company was the one that started spin on oil filters.
First spin ons
