Originally Posted By: ZeeOSix
Originally Posted By: crazyoildude
I always felt if an oil filter filters really good the flow can't be that great. I know when i used to use purolators the pure one did not flow as good as the Classic.
I could tell by my mechanical oil gauges. I am going to be using an ultra soon and want to see how that does in the flow department because i believe flow is very important because dirty oil lubricates better than no oil any time.
Any Thoughts?
As has been said a hundred times, on an engine with a positive displacement oil pump, you can't tell if one filter flows better than another by a simple oil gauge. You would either need a delta-p setup, or if you can run the engine up to near red line with the same oil at the same temperature in both cased and put the pump in to pressure relief, then you might see a slight difference in max oil pressure.
I've ran 5 different oil filter brands on my Z06, have recorded oil pressure vs oil temperature vs engine RPM, and I can see any difference between them all.
BTW - the FU flows and filters about as good any anything available today - even better than the PureOne did, and that's one reason I like the Ultra.
By delta p setup, do you mean something that measures how often the filter (or integrated bypass setup) goes into bypass?
