Originally Posted By: ZeeOSix
So the PSID in the filter may well be close to the same with cold oil as hot oil. In other words, the PSID ratio between engine an filter will remain the same with any temperature of oil because of the fixed flow resistance factors of each.
A 60-1700 cSt fluid flowing through the filter media as freely as a 8.5-11 cSt fluid? This is using Pennzoil Ultra 5w30 and a temperature range of 0-100° F versus ~operating viscosity just as an example.
IMO, if the Modulars didn't go into bypass fairly often, Ford wouldn't be specifying the thread end bypass.
You're not grasping the concept. When the oil is cold and thick, the oil pump goes into pressure relief very quickly ... and the volume of oil flow going through the filter/engine is way less with cold oil vs. hot oil when the pump is in pressure relief. The volumetric flow rate is a key factor is PSID in the filter. So if the flow is much less, then the PSID is reduced due to reduced flow, but increased due to higher viscosity ... and they then cancel each other out to some degree.
I understand the basic concept just fine, but without hard numbers it's all guesswork. With cold thick oil, is the filter the major restriction?
IME, if Ford goes out of their way to spec the thread end bypass valve, and given that I know the kinds of volumes and pressure the Modulars see (higher than most) making the likelihood of a Modular filter seeing bypass greater than say...an LSx, I'll err to the side of caution and stick with filters with the Ford preferred bypass valve location.
