Originally Posted By: GM4LIFE
If I had the 3.6L DI GM engine, I wouldn't use anything other than the factory AC Delco PF63 oil filter. In that case, if anything should happen, GM would be buying the repair and at least you have someone that would hopefully stand behind the damage.
+1 here.
Sometimes you need to think before you let the guy down at "Quick-O Tire" work on your car.
Sometimes when you save, you really lose.
Best of luck.
+1 here.
Best of luck.
