Mirroring the new Ultra design ...The OG Titaniums I have been cutting no longer have the fiber gasket….
Yes, the PF63E has a snug fit with the fiber caps …I think the only spin-on filter with metal end caps that had a fiber sealing ring for the leaf spring was the OG Ultra & OG Titanium. I don't recall any other brand or model using such a design.
One advantage of filters with fiber end caps is that they will seal better than a metal-on-metal seal on the end caps.
Still wire backed, no louvers. But no seal.Mirroring the new Ultra design .... They still have wire backed media, but without the end plate seal and louvers?
Excellent post and as a throwback does anyone remember the OF as a screen door or dire emergency device vs some magic wear protector discussions, ca 2004 or way back?If only someone would invent a filter mount that has a bypass valve mounted in the block. Then the filter could be just a paper cartridge, with 100% of the oil going through the filter when the bypass is closed.
Nah, that will never happen, will it?
As far as this video?
You can’t tell anything from the light except that the seal is not “perfect”. How much oil goes around the case, through that gap? It’s not accurately measured by the flashlight.
This might be important, or it might be much ado about nothing.
When Wix/NAPA Gold went to a dome end bypass valve they still used a metal spacer where the base end bypass valve use to be. That spacer can be seen in the WCW video (starts at point in video). The sealing between the spacer and the end cap is just a thin raised ridge similar to discussed above. Probably good enough, if those parts are flat enough and there's good spring pressure compressing the guts tight.Fwiw,I don't have an issue with metal on metal seal area per se. Wix/Napa Gold has long used it with their base end bypass piece. But there the milling of mating surfaces is fine and a relatively wide area.
With the use of the coil compression shown in vid at 3:33 on the XP/Platinum, no light test, I'd feel pretty good about the seal being maintained. Otoh, I might be less confident of that with the use of stamped flat spring...... Probably good enough, if those parts are flat enough and there's good spring pressure compressing the guts tight.
Two separate functions. The bypass valve in the filter operates on the dP across the filter media. The pump pressure relief ("bypass") operates on the output pressure of the oil pump. A filter could go into bypass before the pump hits pressure relief, or the pump could hit pressure relief before the filter bypasses. It all depends on the settings of each and the operating conditions.Not sure the poppet in an oil filter provides the same functionality as a pump relief valve …
I know …Two separate functions. The bypass valve in the filter operates on the dP across the filter media. The pump pressure relief ("bypass") operates on the output pressure of the oil pump. A filter could go into bypass before the pump hits pressure relief, or the pump could hit pressure relief before the filter bypasses. It all depends on the settings of each and the operating conditions.
