We have a few pressure gauges at the shop that are low on oil what kind of oil is that?, id like to top them off better.
If the works are made of brass, you could drain it and fill with glycerine (if not subject to freezing temperatures). You can't go wrong with silicone oil. A compromise would be to drain and fill with a clear oil (light machine oil, vacum pump oil, compressor oil).Have no idea what oil is in there the gauge is old.
would A/C oil or Vacuum pump oil work?
Indeed … this is what I typically see at work (for air gap)And not all liquid-filled gauges are completely filled either. "Low" may be a relative term.
You should first determine whether they are filled with glycerine or oil. If you mix some with water and it mixes, then it is glycerine. If not, then it is oil. If oil, drain out what is in there, rinse with alcohol, dry, and refill with Vac oil. If glycerine, refill with glycerine (available at drug stores). Better yet, you could remove them and send them to a calibration lab for calibration and service. If they have leaked out half of the liquid, they are probably not reading correctly and should be calibrated.Guys these are half empty or a little less, its hard to see the numbers if its at a certain spot.
we have AC oil and Vac oil that's clear
When I can ill try thatYou should first determine whether they are filled with glycerine or oil. If you mix some with water and it mixes, then it is glycerine. If not, then it is oil. If oil, drain out what is in there, rinse with alcohol, dry, and refill with Vac oil. If glycerine, refill with glycerine (available at drug stores). Better yet, you could remove them and send them to a calibration lab for calibration and service. If they have leaked out half of the liquid, they are probably not reading correctly and should be calibrated.
