http://www.shift518.com/showthread.php?t=28823
Read that thread starting at post 3. I'm "TurboTravis", he's "Volvchandr"
He thinks that oil ratings make no sense because a multigrade oil is thicker when it's cold, and since it's thicker when cold, it should have a higher viscosity number, not lower. He's failing to take into consideration that the "W" rating is tested at low temps and the non "W" number is tested at higher temps.
Feel free to sign up and post, I encourage you to!
