Just like oil takes a lot longer to heat, it takes a lot longer to cool. So while your coolant mightve dropped to 140degrees in 1.5hrs I guarantee the oil is still fairly warmquote:
Originally posted by Patman:
I too worry about the effects of racing my car with cold oil. In order to run the best ET in an LT1, a one to two hour cooldown is often the best thing. But I wonder what harm I'm doing to the engine by running it so hard on cold oil?
If you want your engine to run cool you need a 160 stat and a fan switch - kick the fan on and idle on up to the stage lanes. By time youre ready to go that coolant will be in the 165/170 range ready for action, and the oil will be up to temperature also ready for action.
