How did auto manufacturers come up with the "industry standard" that 1 quart per 1000 miles oil consumption is acceptable? Seems arbitrary and simply a way to avoid correction of poorly manufactured engines.
The only thing I can think of is that if the engine was manufactured with all of the tolerances at the extremes it could use this amount of oil. Example, piston bore at the oversize extreme and the piston at the undersize extreme, etc.
Any insight?
Steve
Any insight?
Steve
