I did an oil change on my recently acquired 2006 G35 coupe about 2000 km ago. I checked the oil level this week and noticed that it was nearly at the L mark on the stick. I added about half a quart until it reached the upper end of the stick towards the H mark. This seems to me like rather excessive oil consumption. I know that the Nissan VQs in the manual transmission equipped G35s were rather problematic but I bought the automatic knowing it would be impacted by the bad engines that those had. The car has just over 100k km.
Am I being paranoid or is it reasonable to expect this level of oil consumption with this engine? I did a transmission fluid change today and there were no visible leaks underneath or on the belly pan. I'm currently using Castrol Edge 5w30 but I've read that others have switch to the Castrol 0w30 (Euro formula) to reduce the consumption. Am I better off using a higher mileage blend and shortening my service intervals?
