Originally Posted By: CATERHAM
If an engine is spec'd for a 40-weight and it generally runs the oil around 14cSt when hot, and this is the recommended grade by the OEM, this would be relatively close to "optimum" for the engine as defined by the OEM. Of course there's going to be a bit of leeway in either direction but generally, let's say that in the range of 12-16cSt is "optimum" for this particular engine.
No, a 40 grade oil (12-16cSt) is way heavier than optimum @ 100C
oil temp' for any engine. In fact most engine oil pumps will still be in bypass at that temp' with a 15-16cSt oil.
An oil's optimum viscosity in HTHSV terms will be somewhere in the 3.5-4.5cP range at all oil temp's if such a lubricant could be invented. (I'll be posting on recent developments in that regard when I find the time).
A 2.6cP HTHS rated 20 grade oil has a HTHSV of around 6cP at 100C so it's still thicker than optimum at that temperature for all engines.
It's the reason more and more manufacturers are specifying that grade and lighter. So aside from availability issues with 20 grade oils, 30 and 40 grades are spec'd to deal with viscosity loss associated with very high oil temp's, fuel dilution and one oil shear.
How can you say that?
Engines designed to run on xw20 are different from an xw40 engine. To run xw20 reliably the engines needs extra block and crankshaft rigidity, this usually requires a forged crank and extra block webbing along with more main bolts.
The xw40 engine probably has a cast crank and not so rigid block, this flexing will will cause bearing clearances to reduce at high RPM/stress loads.
With a xw20 this flexing would be disastrous to the engine resulting in damages to the crank and bearings.
The crank bearing contact will happen long before your oil pressure gauge could even register it and for you to do something about it.
Over the years 4 bolt mains and forged cranks have been used in some engines to increase the rigidity, but the block itself was still lacking the necessary addition webbing.
A xw40 is not too heavy in these engines.
The oil pressure gauge is basically useless in detecting block/crank flex because it will wont show it if only one or two bearings make contact at any given time.
Advising peope to use gauges to determine the optimal viscosity is quackery.
