Oh, forgot...the reason capillary action is so much greater than this creeping, is because to have true capillary action, the fluid needs to be surrounded more closely. This attraction of the fluid to the surroundings is magnified when the surroundings are so close.
The opposite of this fluid-to-surface attraction is easily observed with water on a waxed car. Surface tension is so high, water beads. Decrease the surface tension with a surfactant (soap), and the water flows along the surface, i.e., the bead of water breaks up.
If that doesn't make sense, Molakule could explain it to everyone's satisfaction, I'm certain. It's no big mystery....
