Oil change
Croatia, Europe
Hi,
What is the best oil change interval for small diesel engines. (1300ccm) (Capacity 3.2L). Engine oil is always 100% synthetic 5w40. Car travells about 15k kilometers per year. Mostly city driving.
It depends on the car and it's tech. as much as anything, but;
If your city driving is mostly short journeys then the oil might not get up to full temp so a shorter interval of 10k KM could be beneficial. If you drive for long enough to get the oil properly hot then 20k KM is reasonable.
Since it's city with small oil capacity, I'd change it every 5k Kilometers and never have to worry.
Or you could go a little longer and change every 6 months. Easier to keep up with.
Originally Posted by IvanPletex
Hi,
Which 100% synthetic oil are you using?
So far I have been using Selenia WR 5W40.
On the next oil change I am gonna switch on Shell helix ultra 5w40( since it is GTL based).
If you are changing it every 8-10k kilometers you can use whatever is cheapest that meets the manufacturers specification. The "100% synthetic oil' you have been using is a good oil and could coceivably deliver much longer change intervals but you will need to monitor/test it.
Selenia WR 5W40:
40.0-50.0 % Distillates (petroleum),
hydrotreated heavy
paraffinic (649-467-00-8)
CAS:64742-54-7
EC:265-157-1
Asp. Tox. 1, H304,
DECLL(*)
01-2119484627-25-
XXXX
1.0-2.0 % Zinc
bis[O-(6-methylheptyl)]
bis[O-(sec-butyl)]
bis(dithiophosphate)
CAS:93819-94-4
EC:298-577-9
Skin Irrit. 2, H315; Eye
Dam. 1, H318; Aquatic
Chronic 2, H411
01-2119543726-
33XXXX
1.0-2.0 % C14-16-18 Alkyl phenol Skin Sens. 1, H317; STOT
RE 2, H373; Aquatic
Chronic 4, H413
01-2119498288-19-
XXXX
1.0-2.0 % Reaction products of
Benzeneamine, N-phenylwith nonene (branched)
CAS:36878-20-3
EC:253-249-4
Aquatic Chronic 4, H413 01-2119488911-28-
XXXX
30.0-40.0 % Not classified oils
Hi
For city driving I would change it every 6 months. I suppose only an analysis will help but oil is relatively cheap. 3.2 litre you say? Is it a Ford Ranger?
Is a C3 oil a better choice for a modern turbo diesel engine like this? Something like a MB229.51?
Tikka.
It is Fiat Grande Punto 1.3 MJD, year 2007. I deleted DPF, iam using full SAPS oils for, never had problems with it 182k kilometers. For the next oil change I bought Shell helix ultra diesel 5w40 A3/B4 , API CF.
