Some thoughts on hot oil changes....even if hot/warm is probably the best.
In a half hour of draining cool oil you're not getting all of it out vs hot..always drain hot.
This sort of conflicts with the Bitog notion of using the same oil filter for 2X or 3X OCI's. All of that old oil doesn't come out either. And I'd bet there's a lot more left in the filter and galleries than what's left in the oil pan after a cold drain at 40 deg F.
Hot draining gets all of the sludge and suspended dirt/debris out
With quality oils and filters, conservative oil drain intervals + filter changes, most vehicles shouldn't have any appreciable sludge or dirt/debris in the pan. Whatever there was should mostly be in the oil filter. If you really want to get more of the remaining sludge out of the pan, pour in some quarts of ATF/MMO or some other light cleaning oil right after you've drained the oil....and let it work on the pan for 30-60 minutes...then drain it again. Chase it down with some motor oil. If sludge in the pan was that much of a concern, we should all be doing a lot more steps to get it out, including removing/cleaning it at oil changes.
Hot oil flows and drains so much quicker
I suspect the vast majority of Bitogers are using 0w and 5w oils. Those flow quite easy above 0 deg F. And at the temps most of us probably do oil changes at (35-90 deg F ambient temps) those oils flow quite readily.
