If I understand correctly, you might put 200 hours on virgin lube this year? Or are you saying you've already got 500 hours on it, and you are considering an additional 200 hours?
If the former, you have reasonably fresh oil and you might accumulate 200 hours this year, I would easily recommend extending all the way into next year. A UOA isn't necessary in this case. I've run up to 3 years in my diesel applications (Dmax; Kubota) and never had an issue; UOAs prove it. Oil has no idea how old it is.
If the later, where you've already put 500 down and are looking at 200 more, then a UOA would be a must-have prudent move. Not that the oil would not be OK, but understanding the contamination levels would be important to know. Honestly I expect the lube would still be fine, but you want to assure yourself. Also, if under warranty, do not extend OCIs without first checking with your local dealer regarding the coverage.
This is kind of the typical BITOG question ... I want something and I'm not willing to pay for it. Advice is free. But knowing is far better than guessing.
