I recently got rid of a 2006 Chrysler T&C with the 3.8. So, pretty much the same van. It did use a full quart of oil every 1500 miles so be aware of that. Sold it with 110,000 miles on it because the transmission was acting up. The whole van would shake when it shifted into the top gear. The rpm's would spike too. It had also developed a very loud ticking sound once it was warm. The body was in decent shape except for some rust starting near the rear right wheel well. The power doors had already both been fixed once to work properly again and the rear power lift gate had a mind of its own. Highway MPG's on it were about 22.5. Around town was about 16-17. The electronic MPG thing was always way off. It would say 25-26 from highway use but it wasn't. I would have kept it longer but I wasn't about to sink money into a trans on a 10 year old mini van. I know another guy who had an '05 and his trans went out at 90K. He had it fixed but then it went out again at 118K. I got 10 years out of it. Did have to replace the alternator and the water pump. Had new plugs and wires too at about 85K.
If the one you bought uses oil you can extend your OCI due to adding new oil all the time.
