Originally Posted by Triple_Se7en
Originally Posted by Touring5
Originally Posted by doitmyself
Almost as much oil on the floor as the time I poured 4.5 quarts into the engine fill hole, only to learn that I didn't put the drain plug back in!
I did that once (ONCE!) as well. Also had one occasion back in the middle 70's when the old cannister filter gasket wasn't removed and I had two gaskets on - similar results to what the OP described.
I guess two mistakes in 45 years of changing my own oil isn't too bad (?).
But will you live another 22.5 years to witness the 3rd mistake? Or will you be so old, that you can't get down on the cold concrete anymore to change that oil....... or even drive that vehicle?
I often wonder if we will be changing oils in our next life.... afterlife? Well the answer to that is definitely no. Our orbs will contain no steering wheels, gas or oil. All we will have to do - is think of a destination and we will arrive there instantly.
Want to go to the moon you say?....... well say it and it's done. Can't wait to get to that afterlife stage myself..... wait... on 2nd thought, I'll wait a little while longer. I can still get down far enough to reach that concrete slab.
I'd be looking the bubble over for a drain plug, filter, and grease zerks! I'm still young enough to enjoy my time on the concrete.
