I did an oil change in the VW GTI. I did it from above with an electric pump I have that has a tube that is thin enough to go down the dipstick. The oil change interval is 10000 miles or every 12 months. Last done in 12/22. I have only about 5000 miles on that oil and will let the maintenance shop do the change in December. I did this because I have read that 5000 mile intervals are better for these direct injection, turbo charged engines.
I put in Mobil 1, 0w-40 , European spec with numbers approved by VW.
