That's like another blanket.I don't have any preference for spring or fall or even bi-annual, annual or semi-annual oci.
As to mileage, I've seen 5,000 mi oci where a premium extended drain synthetic is used up and 15,000 mi oci where a cheap blend wasn't. To many variables for blanket statements.
What mileage do you do with the Camry that you need to change twice per year?April and October here.
It's not about miles driven, it's about the type of driving that's done: mostly very short trips where the engine doesn't get warm. In certain situations, the water doesn't even come up to normal temp as shown on the gauge.What mileage do you do with the Camry that you need to change twice per year?
But, since you asked, the last change went 3,763 miles, and this upcoming change will be a bit less than 3,000 miles.
There are those that will say such OCIs are a waste of money, and it may be in some cases, but unless you're doing an oil analysis, you can't be certain. From what I read here, an analysis can cost more than the oil, so from a strictly financial perspective, it may be more economical to just change the oil and maintain a good night's sleep.same here. i do mostly short trips 5 days a week. i rarely get over 5k miles per year. yet i still change every 6 months. the last oil change on my wifes elantra had 2800 miles on it. one coming up in may will have a little less.
Why?I change oil 4 times a year![]()
20k miles a year, 5k mile OCIWhy?
So would you not want the highest TBN to cross winter with? Or high TBN in the Spring and it wont deplete across summer and be "good enough" for winter?I do annuals in the spring. My thinking behind that is the winter is harder on oil around here than than the summer.
You could do 7500 most easily with LESS engine wear. At least on the UOA report20k miles a year, 5k mile OCI
In my case don't think I put enough miles on to be worried about TBN, both engines are easy on oil. While they are both short tripped my Lucerne only sees about 2800 miles a year and the Sierra about 1500. I would also add in my case it probably wouldn't matter when I changed it.So would you not want the highest TBN to cross winter with? Or high TBN in the Spring and it wont deplete across summer and be "good enough" for winter?
I am in this boat with my Ford DI. But the DI is telling me to change the oil 3x a year! Maybe after the engine is worn in it will settle down.
