1999 Mercury Sable, Vulcan engine. Was using regular 10w30 oil, no oil burn, no oil leaks. Changed to Castrol Edge synthetic oil - now my engine making noises as soon as I switched to Castrol Edge. Sounds like piston rods are quietly knocking. Engine sounds loose, maybe tappet noise also. Engine never made these noises before I put the Castrol in it. Also I put 5w30 in it because that is what I thought the manufacture recommended. Have since found out the recommendation is really 5W-20. Isn’t that even thinner? Did I make a mistake? The engine has 128K on it. Should I go back to regular oil before I ruin my engine?
Old Man Chuckles
Old Man Chuckles
