Originally Posted by StevieC
... I don't know if Toyota has a strategy for PCV vapor built into the valve covers or plenum it feeds into but I'm interested to see what it catches if anything.
I intend to run the hoses downward from the PCV into the can and then back up again into the plenum to condense and catch as much as possible. I will also install a 3/8" fuel filter that is cellulose based and see through so that it will catch anything that isn't condensed into the can. ... Stay tuned...
OK, I'll stay tuned.
Be careful that the fuel filter doesn't clog and block the flow, which will cause blowby to back up through the PCV intake.
My Toyota has the PCV in a difficult-to-reach spot on the side of the block, not in the conventional location on the valve cover. They do claim there's a fairly elaborate baffling system to stop most of the mist. It must work pretty well, because this car consumes remarkably little oil---so far. However, several of the mechanically ambitious members of priuschat.com are gung-ho installing catch cans as a tactic to avoid future troubles. I'm reserving judgement.
I can see a neglected catch can potentially creating trouble in winter if it fills so full of condensed water and ice that the engine ends up getting a gulp of liquid water. That's likely one reason (of several) that car manufacturers don't deploy them.
